Allow Users to Change Content Ownership without the View All Content Privilege Enabled
8489
14
08-01-2018 01:59 PM
GregMcNamee
A useful enhancement would be to allow a user to reassign their own content without requiring the permission to see the content of other users. If the "View all" content administrative privilege is not enabled in a custom publisher role, the user will not be able to reassign the ownership of their content to another folder. In our organization, there is private and confidential data that should not be visible to the entire organization.  Users sometimes need to transfer ownership of their items to another folder without viewing the content of the entire organization. Currently, the "View all" parameter under the Content portion of the Administrative Privilege section, must be enabled to reassign ownership of an item.
14 Comments
FayDearing
We definitely need this.
PeterKnoop
With close to 7000 users in our org, relying on admins for re-assigning ownership doesn't scale. It is the users that know when ownership needs to be changed, not the admins.
I would like to see this functionality as well, though as a two-step process. Step one being a user creating a request to re-assign any of the content they own to another user within the organization, while step two is that other user accepting the request, at which point the ownership change actually takes place. This would prevent users from inadvertently or maliciously spamming others with content that is not wanted, and it would give the recipient some awareness of the content arriving, if they want to move it elsewhere, rather than it mysteriously appearing.
Alternatively, if the sharing model in ArcGIS Online were evolved to allow groups to own items, rather than just users, then this functionality, and the extra work it places on users, would not be needed for many of the user cases outlined. Ownership of an item could be tied a group, and when one person leaves the group, then that has no impact, nor extra work, for the other collaborators in the group to continue working with the item. (For example, Google Team Drives versus Shared Drives.)
Danny_Thompson
Absolutely astonished that after 8 years, this important piece of functionality still isn't implemented! What does it actually take to improve something?
Why have :
General privileges
Content  Reassign content
Allow member to reassign only their content to another member with the privilege to receive content
General privileges
Content  Receive content
Allow member to receive content that is reassigned to them by another member with the privilege to reassign content
If neither work unless you have the Administrative privilege VIEW ALL PORTAL CONTENT turned on!?
Users within the same group, should be able to pass items to each other to allow for sharing of workloads, continuity of service across different teams etc. without having to see all content, including content that doesn't belong to a group they are part of, thus erasing all group security settings.
The logic here is terrible!
PeterKnoop
As of the March 2022 ArcGIS Online Update you DO NOT need to grant the administrative privilege for "View all" (Allow member to view all content within your organization) for the Reassign content/Receive content privileges to work. See Transferring ArcGIS Online content between members in an organization.
