I have a ModelBuilder model that creates a Feature Layer results in the results pane of ArcGIS Server web application. The results are displayed with the coloring scheme I defined in a *.lyr file specified in ModelBuilder (the model is used in the geoprocessing server... unfortunately the result cannont show the labels as I specified them (or any labels as I understand from ESRI troubleshooters)
