Aggregation - Toggle / Option to Remove the Aggregate Symbols from legends
1763
03-15-2023 09:31 AM
Status: Open
JTFP_GEO
The number of features/aggregate symbols in the legend isn't always necessary or desirable. There should be an option to remove this from the legend.
2 Comments
temprobertcottreau131313
so remove symbols from the legend, open Styles and select Unique Symbols to show a list of everything in the legend.
To remove an item from showing in the legend, hold the hand over the 6 dots to the left of the symbol and drag it below the dividing line at the bottom of the legend.
JasonHildrethCityofTacoma
My work around was:
1. In map viewer, make a copy of the aggregated layer and disable aggregation.
2. Make sure the copy has symbology that matches the aggregated layer. Set the points for the copy to be slightly smaller than the points used in the cluster layer so they are hidden when things become disaggregated at a large scale.
3. Make sure the copy is underneath the cluster layer so that the points are hidden.
4. Turn off popups/lables from the copy.
5. Remove the aggregated layer from the legend.
Final result (the numbers do not correspond to the number of features in the cluster, but they could):
