Add support for multiple value selection in combobox fields in forms
546
03-05-2026 02:52 AM
Status: Open
Yannick-Atos
Many data models require storing multiple categorical values for a single attribute. A common example is selecting several applicable categories, tags, or characteristics for a feature.
In the form configuration of ArcGIS Online and the ArcGIS Maps SDK for JavaScript Editor, combobox fields currently support only single-value selection.
However, there are common workflows where users need to select multiple predefined values from the same domain.
Current behavior
Combobox fields allow selecting only one value from a coded value domain.
To represent multiple values, users currently must:
  • create multiple boolean fields
  • create related tables
  • or manually concatenate values in a text field
These approaches have several drawbacks:
  • more complex data models
  • reduced usability for editors
  • increased risk of inconsistent values
Proposed enhancement
Add native support for multi-select combobox fields in ArcGIS forms.
Possible configuration example:
fieldName: hazard_types
inputType: combobox
multiple: true
delimiter: ";"
Behavior:
  • Users can select multiple values from the coded value domain.
  • Selected values are stored in a single string field, concatenated with a configurable delimiter.
  • Existing single-select combobox behavior remains unchanged.
Example stored value:
holes;cracks;graffiti
Benefits
  • Supports common tagging and classification workflows
  • Simplifies data models by avoiding additional fields or related tables
  • Improves editing usability in web and mobile apps
  • Provides a consistent solution across ArcGIS editing environments
Tags (3)
1 Comment
EmilyGeo
Thanks for sharing your idea and context. You can expect to see this enhancement in a future update- its on our roadmap, and we’re working through the design and implementation details.
