Ability to remove duplicate labels from feature layer in ArcGIS online
2430
06-07-2018 03:56 PM
Status: Open
by Anonymous User
Not applicable
First, take note that there are no duplicated features in my layer and the layer has not been added multiple times in the web map.
Here is an example of the scenario where I would like to be able to remove duplicated labels from a hosted feature layer:
  • There is a (1) Hosted Feature Layer added to my web map which contains say 20 features / parcels.
  • Each parcel has an individual Object ID, and other attributes in a series of fields.
  • There is also a field containing ownership information.
  • Multiple features/parcels can have the same ownership information.
  • If I want to display ownership labels for each parcel, therefore, my map will display multiple times the same owner's name since multiple parcels have the same ownership attribute.
I would like to be able to remove the duplicated owner names from the labels and display the name only once even if the name comes up multiple times in my attribute table. This is possible when using "remove all duplicates" in ArcGIS Pro Labeling Properties and in ArcMap as well. I would rather not have to remove the repeated owner's names from my attribute table or merge features.
4 Comments
SavannahWinstanley1
I agree that this would be useful, as well as adding a few more placement adjustment options, such as remove duplicates within a fixed distance for line features that may have many small parts together, but only need to be labeled once or twice.
Bathymetry layers labeling is the example that I am thinking of specifically, but street names in custom basemaps as well
ChelseaRozek
6 years later and I still don't see a solution... If they could add a label "only the largest feature" that would be helpful for my use cases if it updates with each extent. I'm trying to label water features, so I don't want to filter based on size. I want everything with a name to label, just not each part of a multipart river feature.
DHamiltonArlington
I also need this option!
AmandaPutri
Yes please for this option.
Does anyone know if the thing can be achieved using Arcade?
