Ability to post Custom Geoprocessing tools to ArcGIS Online
1331
06-08-2023 02:42 PM
Status: Open
AndrewHansford
Esri talks about ArcGIS Online being a true SaaS version of ArcGIS Enterprise. I think into todays world this would be fantastic if it were. The problem being is that you still require a certain number of services to be hosted on prem. For example the ability to create custom geoprocessing tools. You are required to host these on your own environments then access them by adding them into your ArcGIS Online environment.
What should happen is that when you create your ArcGIS Online Instance for your organisation you should have the ability to post custom geoprocessing tools in that environment. Similar to the ability to host your organsiations data in the cloud.
1 Comment
sxw_eaglegis
Hi Andrew,
Custom geoprocessing tools are available in ArcGIS Online in the form of ArcGIS Notebooks, which can be scheduled. The ability to run the notebooks on demand as web tools is part of the roadmap and is planned to be released on the October update of ArcGIS Online.
See here - https://community.esri.com/t5/arcgis-notebooks-ideas/run-arcgis-notebook-on-button-click/idc-p/12405...
