Ability to change an ArcGIS Online username
14411
29
11-13-2017 02:54 PM
Status: Open
GenevieveMontpetit
As an org administrator, I would like to be able to update a username instead of the current workaround which is to create a brand new user and move all content from the old to the new user.
Use cases:
  • A username contains a typo
  • Person changing last name
  • The organization short name is modified in the org's settings, and several user accounts reference the old short name (e.g. jsmith_myorg should now be jsmith_neworg for clarity
Workaround details from Esri support: http://support.esri.com/en/technical-article/000011984
29 Comments
DaveSivertsenz
One more vote. Trying to move to SSO/SAML. Autogenerated usernames 40 characters long! Existing user names can't be standardized/updated. Content on AGOL can be migrated to new account, but finding everywhere else - including community.esri.com, support history, my.esri,  is problematic
Barlow_Benton
I would like to add an additional vote for this. This is causing the move to Single Sign On to be a bit more finicky and persnickety than it needs to be.
mmoore
Hello,
Any movement on this?
Matthew
Marc_Patti
I'm also interested to see if there are any updates on this. I appreciate the ability to add a display name for someone's ESRI profile, but there are a lot of instances where that feature isn't going to be enough.
IanHarshbarger
I am also interested in this.
-Ian
MappyIan
Such a great idea, logged over 7 years ago with nearly 300 kudoses and it's still not implemented.  Esri say they look at the Ideas to direct development but this kind of suggests otherwise.
DC_GISGroup
We just submitted a support ticket for this..we have a AD consolidation project going on in our Org. 700 users impacted (coming into larger domain).  Manually moving them not a realistic option, tons of content, some to groups with shared editing that makes content transfer challenging etc.  AGO should be able to poll SAML for UPN change or allow us to edit manually. Fingers crossed they have a work around!
EmikoCondeso
Yes please, fix this!
CalvinHarmin
Piling on - we have this use case now as well where we need to 'map' Azure AD login to the same naming convention as existing users. It seems like we will have to systematically migrate user content, delete all of our users and have them re-created upon Azure SSO login, and then restore content. This also breaks any collaborations they were invited to. I can't find any other alternative so far.
