Show Attachments in Web Map Popup
247029
416
12-14-2015 08:10 AM
I work with a lot of customers that request the ability to display their feature service attachments in the web map's popup rather than a hyperlink.  The attached script will convert the feature services attachments URL to a field.  You can then display the attachment directly in the popup after some configuration.
Here is a screen shot on how attachments display within a web map popup by default:
Below are the steps to show the attached image directly in the popup:
1.  Add a TEXT/STRING field (i.e. "Picture")  to the feature service that can support a large amount of characters (i.e. 1,000).
2.  Execute the attached GP tool.
3.  Configure the pop-up to Show Images.  Ex:
The image will now display directly in the popup.  Ex:
Notes:
  • the timeout for an ArcGIS Online feature service is set to the max of 15 days.
  • the timeout for an ArcGIS Server service is set to the default 'Lifespan of long lived token'.  The default is 1 day.  This can be changed by going to Server Manager > Security > Settings.  After the long lived token is updated, you can update the expiration parameter on line 33.
  • Since the token will timeout, you can update the parameters in the script so this can be executed with Windows Task Scheduler.  Here is an example of how to configure the parameters:
A video of the workflow can be found below:
https://www.youtube.com/watch?v=WpLJBZ9gnuw
Comments
OrcaMaritime
Jake,
I'm having an error when running the script in Pro. It is saying that my web layer doesn't have attachments, but as you can see on the right-hand side of the image, that it does have attachments.
Screenshot
JakeSkinner
Esri Esteemed Contributor
Orca Maritime‌ can you share the service to an AGOL Group and invite my user account (jskinner_CountySandbox)?
JoeBryant1
Has anyone figured out how to run this script without updating the editor tracking? I'd like to retain the editor username and last edit time stamp of my field collectors. I'm currently using hosted feature services in ArcGIS Online.
JoeBryant1
I figured out I could manually turn of editor tracking on the layer, save, run the script, turn it back on and save again. A little tedious, but it works. Now I just have to remember!
It would be nice to be able to include a "disable" and "re-enable" editor tracking function at the beginning and end of this GP tool. Maybe even allow you to toggle editor tracking off in the user dialog.
DambéSANWOGOU
Hi Jake Skinner‌, i have the same problem, after a few days, my image don't display, i use arcgis Online
JakeSkinner
Dambé SANWOGOU‌ the pop-ups should be retained for 15 days before you have to execute the tool again.  Have you tried configuring the variables in the script and having Windows Task Scheduler run the script (see the example in the document)?  You could schedule the script to run nightly and you won't have to worry about the token expiring, which causes the images to no longer display.
CarlosColegios
Hello:
When I take data with Collector for ArcGIS, (image included), I can not get the image to appear in the pop-up.
Only the link to it appears. What do I have to do to be able to insert it as an image?
In this window, the field of the images (attachments) does not appear.
Thank you
JakeSkinner
Carlos Colegios‌ follow the steps in this document.  You first will add a new TEXT field to your service, and then execute the attached tool to up this field with the URL to the attachments.
CarlosColegios
Hello:
I created the image field (text), but I do not know how to run the
Attachments to Popup tool. I do it from ArcGIS Online. I unzip the tool and
that's where I arrived. What do I do with the unzipped file?
Can you tell me, please, how it is done?
Thank you
Carlos
El lun., 17 jun. 2019 a las 14:19, Jake Skinner (<[email protected]>)
escribió:
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=watches.email.document_comment>
new comment by Jake Skinner
<https://community.esri.com/people/jskinner-esristaff?et=watches.email.document_comment> View
all comments on this document
<https://community.esri.com/docs/DOC-7445-show-attachments-in-web-map-popup?commentID=74552&et=watches.email.document_comment#comment-74552>
JakeSkinner
Carlos Colegios‌ you will need to run the tool from ArcMap or ArcGIS Pro.
SamanthaGriffore
Hi Jake Skinner‌, I'm getting a similar error. I've checked that my feature service is enabled for editing and have added the index to the end of the URL. Any ideas why I'm getting this error?
JakeSkinner
Samantha Griffore‌ what type of authentication are you using for ArcGIS Online?  For example, are you using built-in users, Active Directory, ADFS?  This tool currently only supports built-in and Active Directory.
Also, could you share the service to a Group and then invite my user account (jskinner_CountySandbox)?
SamanthaGriffore
Jake Skinner‌ Invite has been sent. I believe we use local users, but I'm checking on that.
JakeSkinner
Samantha Griffore‌ your feature service URL is incorrect.  It should end with /2.  Here is how I had the tool setup:
SamanthaGriffore
Thanks Jake Skinner‌. Might be a silly question, but how do I know which index number to put in? Is it based on where it is in my list of items in my specific folder/group/content? "2" didn't work for me, trying other numbers now.
JakeSkinner
Samantha Griffore‌ if you go to the Details of the service, scroll all the way to the bottom, and click View:
This will open REST services directory page.  You can then see the index number of the layer (i.e. 2):
If you click on the layer name, you will see it appends /2 after /FeatureServer in the URL.
SamanthaGriffore
Thanks Jake Skinner‌. Unfortunately, still getting the same error. At this point it's not crucial, but a nice to have. I'll let you know if I figure it out.
URL:
https://services6.arcgis.com/ubm4tcTYICKBpist/ArcGIS/rest/services/NR_Projects_Specific_Location/Fea...
Error: Line 34 -- "token = response.json()['token']": 'token'
Completed script Attachments to Popup...
Failed to execute (AttachmentstoPopup).
DambéSANWOGOU
Hello Jake Skinner, I have this error after several attempts. Here is my error message.
Exécution du script AttachmentstoPopup...
ObjectID: 14 successfully updated.
Error:  Line 103 -- "": ('Connection aborted.', error(10054, 'Une connexion existante a d\xfb \xeatre ferm\xe9e par l\x92h\xf4te distant'))
Completed script AttachmentstoPopup...
Échec de l’exécution de (AttachmentstoPopup).
Échec à Wed Aug 28 16:05:48 2019 (temps écoulé : 19,92 secondes)
I also wanted to know if there is another way to display the images after 15 days.
Best regards,
Anselme
JakeSkinner
Dambé SANWOGOU‌ can you send a screen shot of how you have the tool setup?
If the service is hosted in ArcGIS Online, 15 days is the max, however you can script this and use Windows Task Scheduler to execute the script.  See the Notes section above.
DambéSANWOGOU
Thanks Jake Skinner
Ok for this error :
Best regards,
Anselme
JakeSkinner
Dambé SANWOGOU‌ can you send a screen shot of the tool before you click OK/Run to execute it.  Example:
DambéSANWOGOU
Jake Skinner‌ thait is the screenshot, i use arcmap 10.7.7
JakeSkinner
Dambé SANWOGOU‌ can you share the service to an ArcGIS Online Group and invite with my user account (jskinner_CountySandbox) to this Group?  I can run a test with the service.
DambéSANWOGOU
Jake Skinner‌ Invitation sent.
Regards,
JakeSkinner
Dambé SANWOGOU‌ the feature service does not have editing enabled.  You need to enable this since this tool updates a field.
JoeBryant1
Hi Jake, thanks for clarifying that you need to enable editing above. I had to create a new View, make it editable and use that service URL in the script (the layer I am updated is public so I shouldn't enable editing on it).
I'm attempting to schedule this with Windows Task Scheduler and have altered the script as in your Notes. However, there is no attribute "disable_warnings' in the requests module. Any ideas?
Here is the error:
>>> import requests
>>> requests.packages.urllib3.disable_warnings()
Runtime error
File "<string>", line 1, in <module>
AttributeError: 'module' object has no attribute 'disable_warnings'
JakeSkinner
Not sure why you are receiving that error.  What version of Python are you running?  However, that line will not be needed.  You can comment it out.  You may just receive some certificate warnings in the python interpreter when you execute the script.
JoeBryant1
Thanks Jake. I did end up commenting it out with no issues.
I’m on Python 2.7 and ArcMap 10.4.1. I also tried it in Pro 2.3 with whatever version of Python that uses (I’m still confused on how to switch between the two).
Searching around, it looks like the Requests module didn’t get installed with Arc Desktop until 10.5. As I do have a requests module installed, it just doesn’t have the “disable_warnings” attribute, maybe Pro 2.3 comes with a version of the module that doesn’t include this attribute?
FYI: I found the most recent “Requests” module installer on the web: https://2.python-requests.org/en/master/ ; I just haven’t gotten IT to install it yet to test. I don’t see “disable_warnings” in the TOC for the module, though. Stack Overflow says urllib3 is not part of the requests module anymore, as of the 2017 revision (>=2.16.0): https://stackoverflow.com/questions/27981545/suppress-insecurerequestwarning-unverified-https-request-is-being-made-in-pytho
Joe Bryant
GIS Coordinator
WEST YOST ASSOCIATES
direct 530.761.0226
NicholasHumphrey
Is there a way to center to image in the popup?
ShelbyZelonisRoberson
Hi Jake, apologies if this has been asked before but I'm having trouble with using the script with ArcGIS Server. I believe the problem is my Portal Server URL, but not sure what to adjust to fix it. Is it because I'm using a web adaptor URL? Here is a screenshot of my inputs and error message:
Thanks!
JakeSkinner
Shelby Roberson‌ yes, you will need to go around the web adaptor by specifying the Fully Qualified Domain Name and port 7443.  Ex:
https://portal.esri.com:7443/arcgis
PeterGoedbloed
Hi Jake,
I can't get this tool working for Portal for ArcGIS 10.7.1 as I am stumbling upon some token errors:
JakeSkinner
Peter Goedbloed‌ if you copy the URL referenced in the error (i.e. https://portal.domain.com:7443/arcgis/sharing/rest/generateToken) and place it in a web browser from your client machine, does it resolve successfully?  Ex:
TimSolomonson
@JakeSkinner ‌, i'm having the identical issue @SamanthaGriffore is having and haven't been able to resolve the issue.
I've added you to a group with the same title as this post.  the servicelayer in question should be shared to you in there.
Error message:
JakeSkinner
@TimSolomonsonyou need to enable editing on the Feature Service.  You can do this by going to the Settings.
MatthewWithum
Occasional Explorer
Working like a charm in ArcPro 2.7. What are your thoughts on displaying a pdf in pop up rather than JPEG? Any foreseeable, additional configuration required? Thank you for this sweet script, moreover maintaining this forum over the years. Great work. @JakeSkinner
JakeSkinner
@MatthewWithumI haven't tested a PDF, but it should work the same as a JPG.
by Anonymous User
Not applicable
Hi Jake,
what If we overwrite the feature layer? should we setup this again in the web map?
JakeSkinner
@Anonymous Useryes, if you overwrite the layer the field that contains the URL will most likely be blank, so you will have to re-execute the tool to populate it.
GISREAL
Hello. Can you suggest a page where I can learn to do this? I am really a newbie when it comes to script. Thanks in advance!
JakeSkinner
@GISREAL below is a video that walks through the workflow:
DickieRigdon
Hi @JakeSkinner ,
Hope you're still following this thread. I'm getting the same error for line 34 as @TimSolomonson and @SamanthaGriffore.  I do have "Editing" enabled on my layer.  I used /0 in my url as that is what my layer has. Thanks for any tips. -Dickie
JakeSkinner
@DickieRigdon if the service is an AGOL hosted feature service, can you share the service to a group and invite my user account (jskinner_CountySandbox)?  I can take a look to see what's going on.
DickieRigdon
@JakeSkinner invitation sent.  Thanks
JakeSkinner
@DickieRigdon,
The tool is working from me on my end.  Can you send a screen shot of how you have the GP tool configured?
DickieRigdon
@JakeSkinner
Tried it again, same error.
JakeSkinner
@DickieRigdon check your username.  It is case sensitive.  For example, if I try jskinner_countysandbox, I receive the same error.  However, jskinner_CountySandbox works.
DickieRigdon
@JakeSkinner  Success!  That was it.  I was using all lower case in toolbox username.  Funny, I can login though to AGOL using all lower case.
I'll work to complete the rest of your workflow now.
Thank you Jake!
DickieRigdon
@JakeSkinner   Hi Jake, the workflow is working great with the manual token refresh and I'm going to see if the organization can run the Task Scheduler as well.  One question, if new records are added to the ArcGIS Pro dataset, will my same toolbox work with the updated data?  The dataset will constantly grow in entries every month.  I'm building a web map app that will publish the data.
JakeSkinner
@DickieRigdon yes, as the dataset grows, the field you created to store the URL will update each time the script is executed.
Version history
Last update:
‎02-28-2022 04:19 AM
Updated by:
Contributors
