How to display an hyperlink in ArcGIS Online
845
11-13-2020 10:54 AM
JoseSanchez
Hello everyone,
How can I display an field in ArcGIs Online that is ahyperlink in ArcMap/ArcCatalog and opens a folder when clicked
Sample:
FILE:///\\,server>\folder\subfolder
BlakeTerhune
MVP Regular Contributor
It will not be able to open a folder using the OS file explore app. The best you could do is to host it as a virtual directory and allow directory browsing so you can get a list of files and folders in the browser.
JoseSanchez
When using a virtual directory, is there a way to open a specific folder?
file:///<virtual directory>/folder/subfolder
BlakeTerhune
Sure. Make the virtual directory at the highest level necessary and you can browse down from there in the url just like you would expect. For example, D:\temp\virtualdir on the server (or some network drive, etc) could be hosted as a virtual directory and accessed from web browser like https://hostname/iis_virtual_directory_name/someinsidefolder/anotherfolder (assuming those folders exist inside the virtualdir location).
Again though, you will need to have directory browsing enabled if you're going to view the contents of a folder.
DavidForbuss1
It's my understanding that this is a security measure put in place so local files cannot be opened via a link.  You'll probably have to host the file online somewhere as mentioned above.
