Hello Friends,
I have a feature layer in ArcGIS online and it has 180,000 records and most have the features (records) have attachments as well. As the feature layer size is growing, we are trying to archive the data submitted until 31-Dec-2020. I tried two different methods as explained in the below articles
https://support.esri.com/en/technical-article/000012232 (It creates replica using rest endpoint of the Feature service)
In the above method, the process kept running for about an hour, it extracted data but looks like the process failed when extracting the attachment. I am telling this because the status was showing as extracting attachments. It only displays message : Exporting data for layer failed. and doesn't give any details about the issue and the replica doesn't get created.
https://support.esri.com/en/Technical-Article/000015786 (it uses geoprocessing tool in ArcGis Pro to extract the data with attachment)
In the above method, ArcGIS pro keeps running for sometime and then freezes and shut's down. This process also fails in creating a local geodatabase from the ArcGIS online feature layer.
So my question is how I can extract the data from my feature layer along with the attachments and publish it as an archive feature layer.
Thanks ,
Rauf
