Unable to login using Idp Unable to validate SAML response
8491
05-14-2014 03:38 AM
JoseSanchez
Hi all,
We have two options to log in to our ArcGIs online:
- Using your com pany account (trusted connections)
- Using your ArcGIS Account
when I try to log in using  my company account (trusted connection) ArcGIS online shows the folowing error message:
"Unable to login using Idp Unable to validate SAML response"
Thanks
ThomasMontefusco
You did not state your Identity Provider, but this error usually occurs if there is a problem with the certificate or if encryptAssertions is enabled. If still having problems, let us know what Idp you are using.
IangYim
Hello,
I am having this same problem when using Okta IDP.
Do you have a step by step guide on setting up integration woth Okta?
thanks
PS: I am on a trial account
CésarGarrido_Lecca1
Hello Thomas, I Have the same problem , I am using ADFS as a IDP provider.
Jay_Gregory
Did anyone find a solution to this?  I am getting the same error using CA's SSO solution as an identity provider.
