Split values in a single filed using Arcade
1503
09-14-2023 01:53 PM
TimHayes3
I have a table with Field1. Field1 has values in it like these:
21223 Streets Pavement
23432 Parks Forestry
232112 Building Inspections
542134 Fire Prevention
How would I split the values in this field so that 21223, Streets, and Pavement would be separate values in the popup that would look like this:
Vehicle Number: 21223
Department: Streets
Division: Pavement
SteveCole
Honored Contributor
If the data in Field1 is consistent, you can use the Split Arcade function to split the Field1 value based on spaces into an array. Then you can building your popup how you see fit.
SteveCole
Honored Contributor
