Populate ID with value from Oracle Sequencer
713
10-18-2016 06:35 AM
JoseSanchez
Hello everyone,
Using the edit widget in Web AppBuilder is there a way to configure the Editor Widget to populate a field "AssetID" with a value obtained from a Oracle Sequencer.
I am able to do that  in an Vb.Net add-In and also I could do that in the old Web ADF, using this code:
Function NextFeatureClassNumber() As Integer
        ' Find Next FeatureClassID
        ' Call Oracle Sequencer FeatureClass_SEQ
        Dim FeatureClassConn As String = section.ConnectionStrings("FeatureClassConnectionString").ConnectionString
        Dim nextFeatureClass As Integer = 0
        Dim connection As New OracleConnection(FeatureClassConn)
        Dim command As New OracleCommand("SELECT FeatureClass_SEQ.NextVal FROM DUAL", connection)
        Try
            connection.Open()
            nextFeatureClass = CType(command.ExecuteScalar(), Integer)
            connection.Close()
        Catch ex As Exception
            MsgBox("Error: " & ex.Message, MsgBoxStyle.Critical, "FeatureClassEditorExtension")
        End Try
        Return nextFeatureClass
    End Function
