on.once(featureLayer, "before-apply-edits", lang.hitch(this, function (evt) {
2308
04-18-2017 06:10 AM
JoseSanchez
Hello everyone,
On  the Edit Widget,  I am looking for a description of the "on.once"  function?
this.editor.templatePicker.on("selection-change", lang.hitch(this, function () {
   var selected = this.editor.templatePicker.getSelected();
   if (selected) {
      var featureLayer = selected.featureLayer;
         if (evt.adds && evt.adds.length > 0) {
Is is part of the FCalss FeatureLayer
FeatureLayer (legacy) | API Reference | ArcGIS API for JavaScript 3.20
Thanks
RobertScheitlin__GISP
Jose,
   You need to refer to the dojo doc on that:
dojo/on — The Dojo Toolkit - Reference Guide
JoseSanchez
Thanks Robert I took a look to the dojo function.
Concerning the event "before-apply-edits" it gets "Fired before edits are applied to the feature layer."
What I don't understand is where in the source code can I check this event BEFORE and AFTER attributes get populated by the editor on the
this.editor.attributeInspector popup window.
In this sample, the code runs BEFORE it gets modified in the attributeInspector, this is why fields are auto-populated.
I am looking for a way to get the values of the feature AFTER they get entered in the  attributeInspector  . For example how can I check that the ProjectID field has its first 4 digits equal to the current year, 2017.
// Populate field ProjectID: How to check that the 4 first 4 digits are the Current Year 2017
if (evt.adds[0].attributes.hasOwnProperty('ProjectID')) {
I don't have the answer to that.
JoseSanchez
May be I need to use the event "applyEdits"
//add a save button next to the delete button
var saveButton = new Button({ label: "Save", "class": "saveButton"},domConstruct.create("div"));
      domConstruct
.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
      saveButton
.on("click", function() {
        updateFeature
.getLayer().applyEdits(null, [updateFeature], null);
 attInspector.on("attribute-change", function(evt) {
//store the updates to apply when the save button is clicked
        updateFeature
.attributes[evt.fieldName] = evt.fieldValue;
https://developers.arcgis.com/javascript/3/jssamples/ed_attribute_inspector.html
