Feature Layer from SDE FeatureServer does not show any data
3970
11
10-26-2016 11:36 AM
JoseSanchez
Hello everyone,
Configuration:    ArcGIS Server 10.2.2, ArcSDE 10.2.2 using Oracle.
Issue: Feature Layer from SDE does not show any data in FeatureServer ArcGIS Online.
My steps:
 - selected editable feature class in ArcSDE 10.2 instance. The layer is versioned,
 - created a mxd with only this layer. Shared as Service, checked Feature Access and published it in my local server
 - created in ArcGIS Online a Feature Layer pointing to the Feature Server in my local server:
http://[myserver]:6080/arcgis/rest/services/[folder]/[service_name]/FeatureServer/0
After creating the Feature Layer in ArcGIS online, what I do not understand is why my service URL becomes:
http://services.arcgis.com/8Pc9XBTAsYuxx9Ny/ArcGIS/rest/services/[Folder]/FeatureServer/0
I need the Feature Layer to point locally to my server not to services.arcgis.online
How can I do that?
Thanks.
RobertScheitlin__GISP
Jose,
So then why are you creating the FeatureLayer in AGOL?
If you want to just use your local server then just just use your local server url.
JoseSanchez
Hi Robert,
I created a Feature Layer in AGOL pointing to my local FeatureService, but then when I check the Overview tab, for the feature Layer it shows an URL in ArcGIS Online.
 I remember that I was able to do that may be to one previous version 10.0, because it created "Feature Layer" but now AGOL creates "Feature Layer (Hosted)".
How do I create a Feature Layer that points to my local layer for editing purposes?
Thanks
Jose,
   If you are adding this FeatureLayer to a Web Map using Map Viewer in AGOL then just click Add layer > from web > and enter your local servers url. Maybe you are not explaining your desired end result or what type of online app you are creating.
JoseSanchez
I am currently testing web editing with AGOL pointing to an SDE feature class.
I tested also the option "Add layer > from web >" but the layer is not editable in this case, and all the set up you can do in a Feature Layer for editing is missing.
I already tested web editing with AGOL in 2014, but then by default AGOL created "Feature Layer" now it creates "Feature Layer (Hosted)"
Steps in AGOL:
 - create Feature Layer
 - Create Map
 - Create WebApp using a template for Edit.
Thanks
Jose,
   If I add a FeatureServer url to my local machine in a web map on AGOL I do not have any issue editing.
JoseSanchez
Hi Robert,
Is your FeatureServer pointing an SDE Feature Class?  Or are you publishing your data on a FGDB or shape?
Thanks
Jose,
   There is a requirement for the layer to be coming from a SDE Geodatabase for you to even be able to publish a FeatureServer service.
Author feature services—Documentation | ArcGIS for Server
JoseSanchez
Hi Robert,
I am using a polygon feature class for testing purposes where the conditions listed in your link apply.
When using a FeatureLayer pointing to a FeatureServer all information relative to the feature class such as symbols, attribute fields is visible and I can change it. But it looks like the feature is empty because the table view is empty and there is no shape in  the map.
Thanks
JoseSanchez
Hello again,
I am able to edit the FeatureLayer/FeatureDataset with Web Map. So I think I understand how the whole process works, instead of pointing to my local server it makes a copy of the layer in services.arcgis.com but without records. This is why it is empty.
