Experience Builder Export Data Action supports KML?
4243
04-28-2023 02:51 PM
egorbn
Hi folks,
I'm building an Experience with a "Query" widget that targets on of several map layers.
I have allowed the "Export" Data Action on the widget.
The problem is, when I navigate to the "Export All" option in the Actions drop-down in the experience, it only allows me to export to CSV, JSON, or GeoJSON.
My question is: how can I add other export formats to this list? Ideally I would like to add shapefile and KML as options.
Egor
sanderllandawillindecosta
Também estou com o mesmo problema.
SStopyak_BruceHarris
We have the same issue. The lack of options is made even worse by ArcGIS Pro's inability to consume or convert the geojsons produced, yielding invalid errors about the Output XY Domain setting or the geojson not being parsed because it is not written to the ESRI-JSON standard. The geojson is readable by QGIS though. You can just drag and drop it into the QGIS. Must be the ESRI devs are only using QGIS?
Juan_Toro-Killion
I realllllllly need these options enhanced to include KMZ/KML...
SoutheastIdaho
Hi, has there been any progress on exporting to KML yet? Our snowmobilers are using Garmin and other GPS devices and want to import our maps.
