Experience Builder custom widget get graphics
2103
11-27-2023 05:23 AM
liva
Hallo,
I am trying to develop a widget in experience builder. The purpose is, when the user presses a button, the app to retrieve all the user's drawings that exist on the map, in order to get their geometry. This is my code so far, but it seems that it doesn't work correctly. The function getGraphics() works, but the drawings on the map can’t be read.
import { React, AllWidgetProps } from 'jimu-core'
import { JimuMapViewComponent, JimuMapView } from 'jimu-arcgis'
import { Button } from 'jimu-ui';
const { useState } = React
const Widget = (props: AllWidgetProps<any>) => {
  const [jmv, setJimuMapView] = useState<JimuMapView>()
  const activeViewChangeHandler = (jimuMapView: JimuMapView) => {
    if (jimuMapView) {
      setJimuMapView(jimuMapView)
   function getGraphics(){
    const graphicDrawings = jmv.view.graphics.toArray()
    if(graphicDrawings.length > 0) {
      console.log("graphics on map")
    else{
      console.log('no graphics on map')
  return (
    <div className="widget-starter jimu-widget">
        props.useMapWidgetIds &&
        props.useMapWidgetIds.length === 1 && (
          <JimuMapViewComponent
            useMapWidgetId={props.useMapWidgetIds?.[0]}
            onActiveViewChange={activeViewChangeHandler}
      <Button type="primary" onClick={getGraphics}>
      </Button>
    </div>
export default Widget
Appreciate if you can help me…Thank you!
BluntBSE
I have the same question. Jimu Map Views appear to have a "view" wrapper, but this "view" doesn't appear to have the "graphics" property, referenced in the esri tutorial on Graphics.
liva
Thank you for your response. I solved the problem by creating a new graphics layer for my custom widget.
