Error message: Invalid redirect_uri, Error: 400
2396
05-24-2017 10:17 AM
JoseSanchez
Hello everyone,
I am getting the error message below. I am getting this error every time I deploy an WAB/ASP.net application. I was able fix it before but now I am having trouble finding the reason why it is not working.
Error: Invalid redirect_uri
ArcGIS Portal Directory | Home
Error
Error: 400
This error happens when  I deploy my WAB application to a new server, in this case the staging server. Before I was able to fix this issue changing the IIS authentication settings.
This is what  I am doing:
- create application in Web Application Builder in my workstation,
- download the application locally,  create a virtual directory in IIS in my workstation pointing to it
- open the web application with Visual Studio 2012, using the option "Open web Site" and customize it in my workstation
- with Visual Studio 2012, publish the application on the staging server
 - In the staging server with IIS:
       .  Create IIS virtual directory
       . Add application
       . In the authentication settings enable Anonymous and Windows authentication
       . Under Edit Permissions, Security tab, created account IIS_IUSRS
 When calling the web application:
  -  http://[stagingserver]/myapplication  it opens, but after clicking  OK on "Please Sign In" to continue, it pops up a window "Error message: Invalid redirect_uri, Error: 400. See attached image file. I tried to open this same rl in several workstations and it fails
 -  if I log on on the staging server and run the application http://localhost/myapplciation/  It works fine.
I also did another test, creating an IIS virtual directory and application pointing to the server //[stagingserver]/myapplication  and it fails too.
Any ideas of what I need to check to fix this issue?
PS: Some additinal information that might help.
The Web Adaptor installed in my is located in another server http://[anotherserver]:6080
JoseSanchez
FOUND IT!!!!!!!
I spend several days trying to figure out why I was getting this error. First I focused on the IIS Web application that was deployed to a staging server. In this application I changed several parameters related to IIS, authentication and security permits, but it did not work. Then  I copied the application into another server and I was getting the same error.
Finally the issue was in the web mapping application located in our  [http://[MyCompany].maps.arcgis.com ] and used by the application in the  config.json "appId" . It was referencing another server, not the one I am currently deploying.
 To correct this issues this is what  I did:
 -  select the tab "Settings" and verify that the value URL in
Web Mapping Application Settings points to your web application.
 - Also please check the
App Registration
and add your new server in the list of servers.
See attached jpg images for additional information.
