Converting Date to Text
4935
07-31-2023 11:27 AM
Chris_Anderson
I am new to Arcade and am using it to convert a dateTime to a text field inside QuickCapture. The text field should be "MM/DD/YYYY" (no number padding). To do so, I have tried both of the following equations:
"${arcadeExpression: Concatenate([text(Month($feature.Survey_Date_Time),M),text(Day($feature.Survey_Date_Time),D),text(Year($feature.Survey_Date_Time),Y)],'/')}"
"${arcadeExpression:var month = Text(Month($feature.Survey_Date_Time));var day = Text(Day($feature.Survey_Date_Time));var year = Text(Year($feature.Survey_Date_Time));var date = Concatenate([month,day,year],'/');return date;}"
Unfortunately, I keep getting "NaN/NaN/NaN". I tried to use the Text() function to change the result of the Month(), Day(), and Year() results from integer to text, but it does not appear to be the issue.
Any help you can provide is greatly appreciated.
Chris Anderson
KenBuja
MVP Esteemed Contributor
The Text function is the easiest way to convert a Date to a text field.
return Text(Now(), "MM/DD/YYYY")
KenBuja
Chris_Anderson
Thanks! That worked. I was thinking I had to go the Excel route to do the calculation.
