Bug: The statistics of a feature service does not show the correct values on ArcGIS Online map viewer after making attribute edits with attachments from ArcGIS Online or the Collector for ArcGIS applications.
4127
07-01-2015 03:03 PM
SubuSwaminathan1
BUG-000088579:The statistics of a feature service does not show the correct values on ArcGIS Online map viewer after making attribute edits with attachments from ArcGIS Online or the Collector for ArcGIS applications.
FYI - This is a bug I called in. With or without attachments really does not seam to matter.
Thanks
Subu
DanPatterson_Retired
Is this a question or did you want to change your question to a discussion​ within the discussion section?  Just change it from a question to a discussion if that is what you intended.
SubuSwaminathan1
Dan,
I don't see where I can make that change.
It should be around the header of the original thread...I can't change it since I am not a moderator in that section.
