ArcGIS Online REST API - Analyze task
4126
09-24-2014 07:04 AM
AshleyDePottey
I am trying to push a CSV file and publish it as a feature service to an ArcGIS Online for Organization account and am finding the documentation here ArcGIS REST API incomplete and/or inconsistent.
I have been attempting to analyze a CSV (for several days now), but all my requests are returning 200/OK with a mostly-blank html page.  I'd guess that means that I'm sending the wrong parameters, hitting the wrong url, or not setting some required header, but I've tried everything I can think of without success.  Here's what I'm POSTing:
URL: http://www.arcgis.com/sharing/rest/content/features/analyze
Data: token=[valid token]&itemid=fd8faaef968648949802b014bb034db6&filetype=csv
A few other things:
  • I've also tried setting the text parameter to my csv text (which is the goal in the long run) but produces the same result.
  • The documentation is unclear on whether the parameter should be called "id" or "itemid", with one sample and the parameter name as "itemid", but another example as "id".  I've tried both and get the same results
Anyone see this problem before or know a good way to troubleshoot this?
HeikoHeijenga
Make sure you do a POST request and set f=json
