Arcade silently fails when Point is accessed
835
05-27-2022 04:48 PM
DonMorrison1
I wrote some arcade to format a web map pop up and it works OK when I click the Test button but not when it gets called from a pop up.  The code is trying to retrieve the x,y coordinates of the feature centroid.  In the example below I've boiled it down to show that line 2 is causing the problem.  When commented out, arcade returns the expected output. When left as-is,  the popup shows nothing and reports no error. Any ideas>
var center = Centroid($feature)
center.x  // When I comment this out it "works"
return {
	type : 'text',
	text : 'Works'
Tags (1)
DonMorrison1
I tried this again this morning and now it works as expected. Very strange.
DonMorrison1
