Arcade Popup Chart axes labels & styling
2616
11-01-2022 07:27 AM
BartvanderWolf
Hi All,
Trying to compose a popup with a linechart. Using the samples I managed to produce a chart  Not really happy with the result...
Below is my code and a screenshot of my popup containing a ArcGis-Pro chart (picture as attachement) and the arcade media chart. I'd like to alter the arcade-chart so it looks more like the Pro-chart.
Specific questions:
A Can I add x-axes labels?
B Can I style the grapg line?
var relsel = OrderBy(FeatureSetByRelationshipName($feature,"FeatureVerticesToP_v4", ['*']),"POINT_M");
var firstR = First(relsel)
var chartValues = {}
var chartNames = []
for (var f in relsel) {
        chartValues[Text(f.POINT_M, '#,#')] = f.POINT_Z
        Push(chartNames, Text(f.POINT_M, '#,#'))
return {
    type: 'media',
    title : 'TestChart',
    description : 'Chart showing crossection of the walk that day',
    attributes : chartValues,  // replace this dictionary with your own key-value pairs,
    mediaInfos: [{
        type : 'linechart', //linechart | barchart | piechart | columnchart
        //title : '',
        //caption : '',
        altText : 'profile graph showing crossection of the days walk', //altText will be read by screen readers
        value : {
          fields: chartNames,  // choose what attributes to use in the chart
          //normalizeField : '',  // the name of the attribute to normalize by or value
N8-CORR
I'm curious to know if you can add x-axis labels myself.
Carld_Entremont
I had the same problem with the axes labelling. A quick and dirty workaround was to add css to your application...
To add a y axis label use:
.esri-feature-media__container:before{
    display:block;
    font-size: 10px;
    max-width: 50px;
    padding:20% 0 0 0;
    content:"Y axis title here";
To centre the x axis caption label you can use:
.esri-feature-media__item-caption{
    display:flex;
    font-size: 10px;
    justify-content: center;
To centre the x axis title label you can use:
.esri-feature-media__item-title{
    display:flex;
    font-size: 10px;
