Arcade expression for area ranges (max and min) with Null values in labels
2114
11-19-2020 01:35 PM
DianaWilson1
Hi All,
I am working in a arcade expression for label the size range for each parcel with multiple buildings with different size. I have 4 fields: "Area1",  "Area2",  "Area3", and "Area4". There are null values in the within the fields. I wrote those expressions, but they do not work. could you please review it and let me know how will be the right expression.
If(!IsEmpty($feature.AREA1)) {return($feature.AREA1)}
else if (!IsEmpty($feature.AREA2)) {return($feature.AREA2)}
else if (!IsEmpty($feature.AREA3)) {return($feature.AREA3)}
else if (!IsEmpty($feature.AREA4)) {return($feature.AREA4)}
The other expression is:
Min($feature.AREA1,$feature.AREA2,$feature.AREA3,$feature.AREA4)+"-"+Max($feature.AREA1,$feature.AREA2,$feature.AREA3,$feature.AREA4)
With the second expression, as an example I get expression like 0-1050. but I do not want to get the "0", just because there is a null value in the "Area1"
Any advice? thank you!
XanderBakker
Esri Esteemed Contributor
