Add progress bar value based on field to ArcGIS online Map
2686
02-18-2022 10:04 AM
CCWeedcontrol
I am trying to add a progress bar to an ArcGIS online map, pretty much like the example from MikeSchoelen.
https://community.esri.com/t5/arcgis-dashboards-blog/adding-a-progress-bar-to-an-indicator-with-a/ba...
I have tried configuring the Custom Attribute Display in the maps Configure pop-up but I have been unsuccessful. I would appreciate any info on how to do this. I've been trying to do this in HTML but Arcade would be ok as well.
<h1>The progress element</h1>
<label for="file">Downloading progress:</label>
<progress id="file" max="100" value="32"> 32% </progress>
BlakeTerhune
You can use the Text() function to convert other values to a string. However, it might be easier to just do your evaluation as a number.
IIF($feature.PercentCom == 25, 'background-color:#1987bb', 'background-color:#DDDDDD')
CCWeedcontrol
I was able to accomplish this with the following but it only works for "Text" fields. My fields is a Long field.
How can change the Arcade code to accept the long field?
Arcade
IIF($feature.PercentCom == '25', 'background-color:#1987bb', 'background-color:#DDDDDD')
HTML
<span><b><br /><br /><br />Phase</b></span>
<table style=" border-collapse: separate; border-spacing: 6px 4px; width: 100%; table-layout: fixed;">
  <tbody><tr height="16">
    <td style="{expression/expr0}"></td>
    <td style="{expression/expr1}"></td>
    <td style="{expression/expr2}"></td>
    <td style="{expression/expr3}"></td>
  </tr>
  <tr height="24" style="text-align: center;">
    <td>25%</td>
    <td>50%</td>
    <td>75%</td>
    <td>100%</td>
  </tr>
</tbody></table>
BlakeTerhune
CCWeedcontrol
I used the following. took me a while to figure out that ")" went after the $feature.percentage.
IIF(Text($feature.percentage) == '25', 'background-color:#1987bb', 'background-color:#DDDDDD')
