IMPORTANT: November AGOL Update has stripped transformations from web maps
2053
12
11-13-2024 01:57 AM
David_Brooks
MVP Regular Contributor
3 12 2,053
Just giving everyone a heads up, ESRI are aware that the recent AGOL update has caused an issue whereby web maps previously containing transformations are no longer assigned. You can confirm this by opening a web map in ArcGIS Pro and you'll notice that the transformaiton is empty:
I don't have any more information on this, but hopefully others can share their experience and some can also give updates on the fix timeline.
I would be interested to know if this is confined to certain transformations and SRSs. And whether we can hot-fix with AGOL assistant somehow.
UPDATE:
A regression bug, which is a bug introduced following an update, has been identified, fixed and logged with the appropriate product team. This bug has been attached to your case in My Esri for your reference.
  • BUG-000172218
  • Following the ArcGIS Online November Release Hosted Feature layers using British National Grid projection are reprojecting to 0,0
  • Fixed
Please note: a manual clearing of the feature layer cache may still be required to see data in the correct location. This can be done by toggling editing on and off again on a service exhibiting this issue or by performing an edit to the feature data and retrying after waiting for the cache control time to pass (default is 30 seconds)
Tags (3)
12 Comments
Contributors
About the Author
A GIS Consultant specialising in Renewable Energy, Mobile GIS, Offline workflows, basemap caching, Drone photogrammetry and LiDAR. All things Portal, Enterprise and Pro.
