tkinter in notebooks for ArcGIS Online
3130
04-13-2020 03:24 PM
RobertWeber
Keep getting this error when trying to use tkinter in arcgis notebooks hosted in ArcGIS Online.
TclError: no display name and no $DISPLAY environment variable
From what I have seen it this is an environment variable that needs to be set in the docker image.  Using %env DISPLAY= does change variable but doesn't seem to clear up the issue.  I will then get this error:
TclError: couldn't connect to display ":0.0"
Since I do not have the control to alter these docker images used for Notebooks in ArcGIS Online I am wondering if someone from ESRI can look into this so tkinter works in notebooks for AGOL.
My program runs fine when I run it from a jupyter notebook on my local machine.
ArcGIS Notebooks Beta - Online
by Anonymous User
Not applicable
Hi Robert,
Can I ask what are you using TkInter for? TkInter requires a direct connection to a display, virtual or otherwise. You won't be able to present a GUI in AGOL Notebooks as it is a headless environment.
Josh
RobertWeber
Hey Josh - wanted to provide a UI for users of certain notebooks is all really.  It's not a huge deal but would be nice.  If there is another package you are aware of that can accomplish this using the runtime's available in AGOL I am open to suggestions.  I was thinking along the lines of taking an input from dropbox and add, publish, append etc an item.
by Anonymous User
Not applicable
Hi Robert,
I'm personally not too familiar with related packages, but have you looked into using ipywidgets to simulate a UI? You can create radio buttons, dropdowns, display videos.
https://ipywidgets.readthedocs.io/en/stable/examples/Widget%20List.html#Selection-widgets
I'm not entirely sure if that fits your use-case but it could be worth mentioning. Perhaps populate a drop-down with your dropbox items. I hope it's at least a good starting point.
Josh
