Panel button does not handle click event
1058
12-03-2024 07:31 AM
Rijswijk_dev
I tried to create a responsive gui in a notebook using panel, but panel buttons do not seem to receive click events.
Here is a demo of that issue:
https://arcg.is/WGnqn
The debugger does not give me a clue.
Is there a way to resolve this ?
Tags (3)
ShaneONeill_144
We appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
Rijswijk_dev
Okido,
I am not yet sure if this is a bug, may be some extra initialization code is needed.
But if there are no responses to this issue after the weekend, I will create a support issue.
