Feature selection from ExB analysis widget coming to web tool as dictionary
3361
10
12-18-2024 01:56 PM
jmaxwell_braun
I have a Notebook published as a web tool and configured for use in the Analysis widget in ExB. I have the input parameter type set to Feature Set. I select the features, set it as the analysis input, run the tool. It sends the features to the notebook/web tool, but they do not appear to be a feature set.
I get errors trying to do any operations on the feature set in the notebook. It says the type is <class 'dict>. Am I doing something wrong on the input side, or do I need to convert it from a dictionary to a feature set first? If I do need to convert it first, I'm not sure how to do that.
The data populated into the input parameter starts off like this:
 {'nextObjectId': 1, 'showLegend': True, 'layerDefinition': {'id': '193db8743d9-layer-40', 'name': 'Sample Grid - Selection', 'objectIdField': 'OBJECTID', 'geometryType': 'esriGeometryPolygon', 'fields': [{'alias': 'OBJECTID', 'editable': True, 'name': 'OBJECTID', 'nullable':...
Any insight would be appreciated.
2 Solutions
jmaxwell_braun
Apparently I needed to create a feature collection from the dictionary. My input parameter is inputFeats, so doing fc=featureCollection(inputFeats) solved it. After that, I was able to query the new feature collection like usual to get a featureset.
Now I have a different issue where only two of the attribute fields are being sent to the web tool.
AndrewGriffin2
for passing a layer added from upload data to the webtool, you can configure you input parameter for a feature set and default value you can use the dictionary mentioned above. {'nextObjectId': 1, 'showLegend': True, 'layerDefinition': {'id': '193db8743d9-layer-40', 'name': 'Sample Grid - Selection', 'objectIdField': 'OBJECTID', 'geometryType': 'esriGeometryPolygon', 'fields': [{'alias': 'OBJECTID', 'editable': True, 'name': 'OBJECTID', 'nullable':...
jmaxwell_braun
LisaTunnell
Hi, could you share how you are doing this? I can't find any tutorials.  I am working with a notebook in AGOL and have set an input parameter as FeatureSet.  It comes in as a dictionary. What I am really trying to do is exactly what you have described here: select features in the map and use those as input utilizing "Set as Analysis Input" It doesn't seem to be working AT ALL, but figuring out this piece would be helpful.  Once I add the featureset and the insert it as a variable, the following is added to the notebook:
selParcels = {
"url": "https://services6.arcgis.com/asdfsdfsdfasd/arcgis/rest/services/MyPArcels/FeatureServer/2"
How do I convert this or actually get a featureset from it?
ClaytonBurns2
 @LisaTunnell were you able to figure out how to select a feature(s) from the map to be the input into the published web tool? I'm having the same problem you described above where the entire map feature layer becomes the input. I tried @jmaxwell_braun suggestion below, but haven't been able to get it to work yet.
Thank you for any help or advice!
LisaT
Wow, I am sorry this is so late.  My company blocks a lot of my emails and so I don't see these unless I look at the blog again!
I was able to figure this out.  I have a parameter called parcelSelect that is a featureset.  It either gets set by drawing on the map (enable the drawing tool in the custom tool settings in ExpBuilder) or by sending the results of the select tool.  You also must enable the "Send Feature Collection Instead of URL" setting in the field settings of the custom tool in ExpBuilder.  Once you have done that, you can enter the code:
selParcelsfromTool = features.FeatureCollection(parcelSelect)
selParcels = selParcelsfromTool.query()
You can also have it return the sdf:  selParcelsfromTool.query().sdf  and you will be able to do different things with it.
NOTE: If you are using the select tool and then using the "set as analysis input" to send the selection to the tool, the "Attribute Selection" option of the select tool MUST be turned off.
I hope this helps!  If you already found the answer, I hope it helps someone....
jmaxwell_braun
@LisaTunnell I would remove the selParcels variable and URL. It did that for me too but I just commented it out.
Assuming selParcels is your input variable, you would do something like:
selParcelsFC = FeatureCollection(selParcels)
selParcelsQuery = selParcelsFC.query
You don't need to define the selParcels anywhere before the first line above. The first line converts from dictionary to feature collection. Second line will get you a feature set that you can actually work with.
I couldn't find good tutorials either, so just had to kind of stumble through it. Still a work in progress.
AndrewGriffin2
jmaxwell_braun
@AndrewGriffin2 are you saying to use the dictionary mentioned above as the default value?
AndrewGriffin2
If your interested in a layer added from upload data? That layer won't have a url. So you need to updated your input parameter so the rest of your code in your notebook knows what dictionary keys to parse etc.. you can get your own dictionary by first publishing your .shp. then do a notebook with input parameter feature set with {'url': 'whateverFeatureserver/0'} output parameter string then go and json.dumps(input)
jmaxwell_braun
Thanks @AndrewGriffin2 . I'll give that a shot. I guess I didn't understand the purpose of the default value field. The documentation on this is pretty sparse.
