Converting KML Files to Hosted Feature Layers within ArcGIS Online/Portal
937
12-17-2025 09:47 AM
dgreenin
Good Afternoon,
I am currently looking for the a solution that meets the following requirements:
  1. KML files can be converted directly to hosted feature layers within ArcGIS Online/Portal.
  2. KML files are uploaded directly from computer and not hosted as items within ArcGIS Online/Portal.
  3. The created hosted feature layers maintain the same symbology as the original KML files.
My current understanding:
  • KML files can be uploaded to ArcGIS Online/Portal but remain as KML file types limiting usage and functionality within Web Maps (ie. cannot alter symbology, no labeling, no attribute table).
  • Map Viewer analysis tools do not offer a KML to Hosted Feature Layer conversion.
  • KML files can be converted to feature layers within ArcGIS Pro and then published to ArcGIS Online/Portal. *This is a limitation if users are not familiar with ArcGIS Pro.
In this case, publishing a custom ArcGIS web tool appears to be the best approach using either of the following options:
  • Publishing an ArcGIS Pro python toolbox to ArcGIS Online/Portal as a web tool.
  • Publishing an ArcGIS Notebook hosted within ArcGIS Online/Portal as a web tool.
Any advice and/or examples would be greatly appreciated.
Best,
dmorrissey_VHB
It looks like you didn't get any help on this.  Did you make any progress?  I'm also very interested.
MirandasheherMcCall
Came here for this same inquiry!
@dgreenin did you successfully publish a toolbox for Enterprise portal uses to convert? If so, do you mind sharing a how-to and the script?
