Changing the Online BA Data Source in Notebook script fails
406
09-05-2025 02:47 PM
GaryChristensen63
I'm using a Notebook in ArcGIS Pro to run the Enrich GP tool to add demographics in several countries.  The script fails when attempting to change the data source of the environments.  A copy of the python command when running the GP shows as:
          with arcpy.EnvManager(baDataSource="Online;AL|census;"):
                     arcpy.analysis.Enrich("<Layer>", out_path, variables, buffer_type)
AL is the country code which changes with each iteration.  I create a variable named "source" which looks the same as the GP output shown above.  In the script the syntax looks like:
           with arcpy.EnvManager(source):
But when I run it, I get this error:
EnvManager.__init__() takes 1 positional argument but 2 were given
 It appears arcpy.EnvManager () does not accept variables.  Can someone confirm this?  Is there a way to programmatically change the enrichment source country?
