ArcGIS Notebooks AI Assistant
646
03-30-2026 08:16 AM
YuriPotawsky
Reintroducing the ArcGIS Notebooks assistant!
Now available in an ArcGIS Online Beta, the ArcGIS Notebooks assistant is an AI-powered tool that accelerates your Python coding workflows.
  • Generate code — Use natural language prompts to create Python scripts for spatial analysis, content management, and automation.
  • Explain & debug — Get line-by-line explanations of existing code and targeted suggestions for fixing errors.
  • Integrated workflow — Works directly inside your notebook, covering the ArcGIS API for Python and ArcPy.
We want to hear from you:
As an early adopter, your feedback directly shapes how this new tool evolves. Share what's working, what could be better, and what you'd like to see next — join the conversation in our early adopter community and help us build the best experience possible!
Join the Early Adopter Community here: https://earlyadopter.esri.com/key/ArcGISNotebooksAssistant
Relevant Docs:
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/introducing-the-arcgis-noteboo...
https://doc.arcgis.com/en/arcgis-online/create-maps/notebooks-assistant.htm
