VRP Analyst
3658
12-19-2013 10:28 PM
AlesgerMammedov1
Good day.
I am learning VRP Analyst. I read the book tutorial Network Analyst.
I did Exercise 7 steb by step.  The solver solved this tak  and show me results.
But the results didn' t show route to the Servise Depot.
Although I add Route Renewals for each track.
Who can write to me? what is the problem ?
Please Help me.
Thank you for your answer
NaAn
Could you please show me the picture of your routes? If the Output Shape Type is set to None, you won't be able to see the route shape.
Thanks.
Anna
AlesgerMammedov1
Thank you very much for your answer.
I solved this proublem. I only, remove network analyst layer and add it again and then I could see results.
Best regards Alesger.
