Service area anaylsis : Adding a fixed amount of speed to roads on maps to calculate area
1474
03-09-2021 07:50 AM
JodiHambides
I am trying to create service areas for emergency vehicles with a 10 minute travel time. However I  want to add an additional fixed amount of speed for the vehicle to travel at on top of the posted speeds of the roads. For example, if the speed is 50 km on city streets and 70 km on streets outside of city boundaries I want to be able to add 10 km/hr to each so it would become 60 km/hr and 80 km/hr. I have the basic license so I am wondering if this is possible at this level.
Thank you.
JaySandhu
If you are able to edit your street data and re-build the network dataset, then you can add a new travel time fields, calculate the new travel time values according to your needs, add a new impedance attribute to your network dataset from these fields and rebuild the network. Now use the new impedance attribute in your analysis.
If you are unable to edit, another approach can be to use barrier polygons with scaled cost, not restriction values in the service area layer. You can create a polygon over your study area and set the scaled cost to 0.9  and all the streets that fall in that barrier polygon will have their travel times reduced by 10% and thus your vehicle can go further. You can adjust the cost to 0.85, etc. as needed for your analysis. The only issue might be that if you have a lot of streets that fall inside the barrier polygon then it can be slow to load the polygon during analysis.
Jay Sandhu
