Routing Service ignoring one-way restriction
1110
11-01-2018 12:11 PM
KennieHarris
I built a street network and included one way restrictions. When I run routes in ArcGIS Desktop is runs correctly. When I publish a service from that same network it ignores the one way restrictions. What is happening?
JaySandhu
The first obvious thing to check is that the published routing service has the oneway restrictions turned on and not off as part of the service. You should be able to bring up the properties of the route layer in ArcMap that was used to publish the routing service.
Jay Sandhu
