Route Using All Segments
1723
10-12-2012 09:37 AM
MeganBirch
I am trying to generate a route that will drive every road in an area in the least amount of time.  In other words, I need to have a vehicle drive every road in a neighborhood using the most efficient route possible.  I've tried using the segment center and end points as stops, but this method is requiring a lot of fine tuning.
Does anyone have any advice or a workflow they could recommend?
JoeBorgione
This sounds something like the Chinese Postman problem that as far I as I know is not supported in NA.  Perhaps Jay S or one of the Network Analyst developers can chime in on this one.
MeganBirch
Thanks for the response.  I was beginning to suspect that might be the case.  I guess we'll just have to continue with the trial and error method of creating "stops" and routing to them.
RamB
Refer this for a slight improvement
http://forums.arcgis.com/threads/17151-Shortest-Route-problem
regards,
