Problem of using tutorial to create a network dataset
14327
22
07-13-2021 12:23 AM
AnnMak_hku
I get this error message: "Get this error message: "Error: The network dataset properties were not updated. [excetion from HRESULT: 0x80040301]" when using the tutorial data (San Diego Dataset) to create the Network Dataset from ArcGIS Pro.
LeeIrminger
I just hit the error and found this post. Your work around of hit cancel then go back to the properties and hit ok worked and the error did not show again.
I had previously created a network dataset with a different name inside the dataset I'm using, deleted it, then created the one I am using now.
MelindaMorang
Okay, thank you. That's consistent with the behavior we saw when testing. This should be resolved in the 2.9 release.
DanielMcCurdy23
I got this problem right away after the first time I created the network dataset and went into the properties to change it.
MelindaMorang
Hello, everyone. This issue proved to be a bit weird - difficult to reliably reproduce, and some of us could and some of us couldn't. However, we believe we have fixed it. The fix will be in the upcoming ArcGIS Pro 2.9 release. For anyone reading this in the future: If you see this error in Pro 2.9 or higher, please leave a comment here with details about your workflow so we can try to figure out what we missed. Thanks.
LixiaonaYu
I was doing the same tutorial and get the ERROR 030222: The network dataset cannot be created from the given parameters.
MelindaMorang
Hello Lixiaona.  This looks like a geoprocessing tool error, so the problem is unrelated to the issue described by the other users in this post.  The problem they experienced was related to clicking the OK button on the network dataset properties.
Please describe the parameters you've used in the tool or post a screenshot of the tool dialog.  You might also consider making a fresh post in a new topic because this is a separate problem.
LixiaonaYu
I am using Pro 3.0
druinm
I came across this error after running the "Create a Network Dataset" tool. I am currently using ArcGIS Pro version 3.3.0. The fix I found was to copy the path of the Transportation File GDB from the Catalogue and paste it into the Target Feature Dataset parameter.
Pål_Herman_Sund
Hi, I get this message when trying to copy a Travel Mode in one of the (in-house) network datasets, but not in all. I will tru to troubleshoot it. Pro 3.2.2
MelindaMorang
If you can share your data and the changes you made to the network dataset properties that reproduce the problem, we can take a look.  Alternatively, you can submit a ticket through Esri Support (or through your distributor), and we can look at it that way as well.
