Environment: ArcGIS Pro 3.5.4 / TomTom Intermediate Traffic Data for Hong Kong
I'm working to integrate TomTom OpenLR Live Traffic feed in ArcGIS Pro.
Following the instructions published on the "Work with Live Traffic" article,
Current time : 11/18/2025 5:46:52 PM
Last Updated : None
Start Window : None
End Window : None
Speed Data Available : False
Road Closure Data Available: False
Messages warning. Traffic speeds not updated because N_1_OpenLRCache table is empty.
warning. Failed to retrieve traffic data.
"lastUpdatedMessages": [
"description": "Traffic speeds not updated because N_1_OpenLRCache table is empty.",
"type": "warning"
"description": "Failed to retrieve traffic data.",
"type": "warning"
Question 1: Is this a bug??? What does this error mean? How can I fix it?
I ran procmon and tcpmon to watch Pro and yes, indeed it was able to access the tomtom traffic feed server.
Not to mention there appears to be traffic data in map view ... So clearly Pro is lying to me here 😅.
Question 2: The document says "The appropriate network attributes for Functional Road Class, Form of Way, Travel Direction, and Length" How do I configure the Network Attribute Mappings? What is the correct workflow for this?
Question 3: I think my scenario is the "access to traffic feeds from a data provider such as TomTom" option (as documented) but the workflow seems to forget to talk about this. I see data in the map but all indicators shows red and errors (see attached "BuildOpenLrCache" and "Live Traffic Data Status" screenshots). How can i reliably know Pro fetched the data? Are these error indicators bugs in this part of the product?
Question 4: I have access to the TomTom incidents data which I also configured in the .traffic file but it seems like Pro didn't bother to fetch that.
a) How can I make Pro fetch and more importantly use the incidents data?
b) How can i ensure the Route solver will use the traffic data as a factor in its calculation?
c) How do I incorporate the incidents data for incorporation into Route solver?
Many thanks,
Derek
Network Dataset Properties for Network ND
Hi @FrankK
Apologies for the delay - Spent some time to take a deep look into this and wanted to share some findings:
@FrankK wrote:Quick answers to some of the above
Q1
- give the files in the openlr.75eaa3e... folder it does not look like it is pulling down file, you should have files of the form "speed.*.dat" files
I can confirm yes, it does look like the OpenLR speeds info file wasn't created:
speeds-info-missing
Here is some telemetry from the ArcGIS Pro Diagnostic Monitor;
Specifically, I had the map with the network dataset open and ran the "BuildOpenLRCache" geoprocessing tool.
(Of interest: a lonely untagged "Parse error" entry)
parse-error
Not sure what the parse error is. Lets ensure you can download the files outside of pro. I have attached a zip that with use a Python and a "traffic" file to download the data. Update the .traffic file with your apikeys and the path to your pem file. Then run the python script ... Usage: python get_protos.py <traffic_file>
When I run this I get the files below
Trouble-shooting this in the past sometimes the issue is the pem file, its incorrect or out of date.
Hi @FrankK ,
Please see below:
Troubleshooting this in the past sometimes the issue is the pem file, its incorrect or out of date.
Here's the output from running the getproto.py (+ .traffic):
getproto.py output
I also get the same files as you:
getproto output files
Let me know if you need anything else!
Derek
