ODCM "solve did not find a solution" error with arcpy.nax.solve on valid origins/destinations
2291
10-31-2022 03:44 PM
PhilipOrlando
I am trying to run an ODCM using arcpy.nax and I'm seeing this "Solve did not find a solution" error when running the example code below.
# Solving OD Cost Matrix...
# OD Cost Matrix solve failed.
# [[-2147200956, 'No "Destinations" found for "Location 1" in "Origins".'], [30212, 'Solve did not find a solution.'], [-2147200971, 'No solution found.']]
import arcpy
import os
# Check out the NA license or alert error
class LicenseError(Exception):
  pass
if arcpy.CheckExtension("Network") == "Available":
  arcpy.CheckOutExtension("Network")
else:
  raise LicenseError("You need the ArcGIS Network Analyst extension license. Please contact your KP administrator.")
try:
  # Set environment variables
  nds = r"path/to/StreetMapPremium/FGDB/StreetMap_Data/NorthAmerica.gdb/Routing/Routing_ND" # <path to your network dataset>
  gdb = r"path/to/scratch.gdb" # <path to your working geodatabase>
  in_origins = os.path.join(gdb, "in_org") #   nw block group weighted centroids
  in_destinations = os.path.join(gdb,"in_dest") # nw pc mob locations
  out_lines = os.path.join(gdb,"od_cost_matrix_lines")
  nd_travel_modes = arcpy.nax.GetTravelModes(nds)
  travel_mode = nd_travel_modes["Driving Time"]
  # Instantiate a solver object
  odcm = arcpy.nax.OriginDestinationCostMatrix(nds)
  # Set object properties
  odcm.travelMode = travel_mode
  odcm.timeUnits = arcpy.nax.TimeUnits.Minutes
  # odcm.defaultImpedanceCutoff = 20
  # odcm.defaultDestinationCount = 2
  odcm.lineShapeType = arcpy.nax.LineShapeType.StraightLine
  # Load inputs
  odcm.load(
    arcpy.nax.OriginDestinationCostMatrixInputDataType.Origins, in_origins)
  odcm.load(
    arcpy.nax.OriginDestinationCostMatrixInputDataType.Destinations, in_destinations)
  # Solve the analysis
  print("Solving OD Cost Matrix...")
  result = odcm.solve()
  # Export the results to a feature class
  if result.solveSucceeded:
    print("OD Cost Matrix solve succeeded.")
  else:
    print("OD Cost Matrix solve failed.")
    print(result.solverMessages(arcpy.nax.MessageSeverity.All))
except Exception as e:
  import sys
  tb = sys.exc_info()[2]
  print(f"An error occured on line {tb.tb_lineno}")
  print(str(e))
 The origin in question has the following coordinates: 33.492278, -117.247194
The destination in question has the following coordinates: 33.90478, -117.4693
The ODCM solve succeeds when running by hand within ArcGIS Pro, however, this approach is calling arcpy.na methods behind the scenes, instead of arcpy.nax.
arcpy.na.MakeODCostMatrixAnalysisLayer(r"/path/to/StreetMapPremium/FGDB/StreetMap_Data/NorthAmerica.gdb/Routing/Routing_ND", "OD Cost Matrix", "Driving Time", None, None, None, "LOCAL_TIME_AT_LOCATIONS", "STRAIGHT_LINES", None)
arcpy.na.AddLocations("OD Cost Matrix", "Origins", "in_org", "Name # #;TargetDestinationCount # #;CurbApproach # 0;Cutoff_Minutes # #;Cutoff_TravelTime # #;Cutoff_Miles # #;Cutoff_Kilometers # #;Cutoff_TimeAt1KPH # #;Cutoff_WalkTime # #;Cutoff_TruckMinutes # #;Cutoff_TruckTravelTime # #", "5000 Meters", None, "Routing_Streets SHAPE;Routing_Streets_Override NONE;Routing_ND_Junctions NONE", "MATCH_TO_CLOSEST", "APPEND", "NO_SNAP", "5 Meters", "EXCLUDE", None)
arcpy.na.AddLocations("OD Cost Matrix", "Destinations", "in_dest", "Name # #;CurbApproach # 0", "5000 Meters", None, "Routing_Streets SHAPE;Routing_Streets_Override NONE;Routing_ND_Junctions NONE", "MATCH_TO_CLOSEST", "CLEAR", "NO_SNAP", "5 Meters", "EXCLUDE", None)
arcpy.na.Solve("OD Cost Matrix", "SKIP", "TERMINATE", None, '')
# Start Time: Monday, October 31, 2022 9:54:53 AM
# Succeeded at Monday, October 31, 2022 9:54:54 AM (Elapsed Time: 0.81 seconds)
Can someone from Esri help me understand why the same origins/destinations are returning different results depending on whether arcpy.na or arcpy.nax methods are used? Any insight is appreciated!
AmlanR
by Esri Alum
Esri Alum
Hi Philip!
Could you provide me with a little more detail on what version of Pro you are using and the SMP data?
I did try it an in-house version of Pro 3.1 and it failed within Pro as well. Upon further inspection, I found that the street on which the origin is located does not allow automobile. Unchecking 'Driving an automobile' in the travel settings resolved the issue.
I would still like to reproduce the issue in-house by replicating your settings and software version.
PhilipOrlando
@AmlanR, thanks for the info! I'm using ArcGIS Pro 2.7.3 and SMP 2021.3.
I did some more digging yesterday and discovered that the Rounting_ND data that comes with Business Analyst was being selected from within the GUI (instead of SMP). Pointing my ArcPy script to this Routing_ND resulted in a successful ODCM solve.
Is there any other way to handle these points besides unchecking the "Driving an automobile" setting? Ideally, I would like this point to snap to the nearest edge where this is allowed instead of having to alter the travel mode.
