OD cost matrix
3393
01-08-2016 12:29 AM
BjornSchadenberg
Is it possible to change the output of an od cost matrix in such a way that instead of getting, for example, 10 rows per origin with the distance to the 10 destinations, but to get for each origin one row with 10 collumns with the distances.
Bjorn
NeilAyres
You could try the Pivot Table tool in Data Management / Table
XanderBakker
Esri Esteemed Contributor
If you don't have access to an Advanced license (required by this tool) you can consider converting the Lines featureclass to Excel and create the pivot table there.
