Network Dataset only opens in Read-only
2030
7
06-06-2024 03:04 PM
amarcz_cc
Last week I built a network dataset on my testing server and it worked well and I like the results.
Now I am attempting to rebuild it on my production server but encounter an issue where it will only open in read-only mode. I just want to review some of the scripts in restrictions / hierarchy that I set but am unable to open them to inspect.
I have verified there are no locks, or connections, attempting to close and reopen ArcPro, restarted my computer, and even tried to old soft reset of renaming the folder Esri_OLD.
Any ideas as to why this is occurring?
ArcPro 3.2
Dataset version of 10.1
nick_of_the_north
I had a similar issue. It turned out to be caused by versioning. Turning versioning off for the feature dataset cleared the "read only" issue.
JaySandhu
Have you checked if you have a read only file share? Or you can try to copy it to another location and see if that works?
Jay Sandhu
amarcz_cc
It is within an sde, but I have removed any locks or connections to it and it persist. It is on a dev server that only I have access to and no services are running off it.. So I am hesitant to relocate it.
EdidiongEkanem
Hey, could you find any solution to this yet ?
amarcz_cc
@EdidiongEkanem I believe after you publish the Network Dataset to Portal that this occurs. To make any changes, you might have to delete it from Portal, then republish.
nick_of_the_north
Brian_McLeer
MVP Regular Contributor
I had the same issue, and unregistering as versioned work for me. Thank you @nick_of_the_north
GeoFUNKE
I have the same issue, The Feature Dataset is not versioned. is there another Versioning-Setting somewhere else?
