Network Analyst VRP ribbon tool, ND source, error
850
08-01-2020 09:09 AM
HenryPeng
When I was using the Solve Vehicle Routing Problem geoprocessing tool I there is the required field of Network Dataset. I've been using a local file from Business Analyst. Using the new Network Analyst VRP tool, how do I point it to a local ND file? Also, I followed along with your 2020 Esri video mapped over everything I recalled as essential from the gp tool and have Travel Settings/Mode set to Driving Time. I ran the ribbon tool but got these errors. Where would I look to correct these issues? Thanks!
ERROR 000800: The value is not a member of Drive Time | Truck Time | Walk Time.
Failed.
ERROR 030024: Solve returned a failure.
Failed to execute (Solve).
HenryPeng
I figured this out. I deleted the VRP layer and started over. This time I first went to Analysis/Network Analysis/Network Data Source/Change network data source and set it to the local file. Then I created a new VRP and ran through the process. It looked like it ran but no routes were created. Then I noticed my Time Field Units was set to minutes when they were actually hours in my Routes table. Once I changed it to Hours it ran and produced routes. Fun stuff!
