Network Analyst Vehicle Routing Problem - Unsolved Orders at cul-de-sacs - partial solve due to violated constraints - ArcMap 10.4.1
1706
10-24-2019 02:34 PM
AlstonHicks
For the subject issue, what setting can I try changing that will allow these endpoint (cul-de-sac) orders to solve?  I have it set to allow...shouldn't it solve then?  I've tried changing things multiple times and must be overlooking something.
JaySandhu
Can you reach these locations using a regular route instead of VRP? I am wondering if there are network issues (oneway, etc.) that may cause no paths to be found.
You can also use the Network Identify tool on the NA toolbar to examine the connectivity of the edges in that area.
Jay Sandhu
AlstonHicks
Thanks, the Network Identify helped, these specific cul-de-sac segments should have Adjacent Edges like other cul-de-sacs, but they do not.  I had added these segments after I built the network.  Even though I rebuilt the network, I'll either rebuild it or figure out how to fix these dirty areas.  Thanks for your quick response.
Alston Hicks
