Network Analyst Turntable Schema
8422
10
10-24-2010 08:38 AM
AndrewLee
Hi all,
I am stuck with the turn feature class field description from ArcGIS Help 9.3 online.
I have a turn shapfile and I need to convert it to turn feature class in order to include it in the network dataset.  However, I am confused with the required fields, such as Edge#End, Edge#FCID, Edge#FID, and Edge#Pos.  The field description from the online help is not that clear.  Can anyone help me here please?  If it's possible, can you show me an example please?  I prefer an example because I learn better with seeing the real thing.  Thanks very much in advance!!  Any help is appreciated!!
Best!
AlexeyTereshenkov
Turn Table to Turn Feature Class tool is meant to convert ArcView 3.x or ArcInfo Workstation Turn table, therefore tool expects the input to be in that specific format.
If you have your turns from Navteq/TeleAtlas, consider using the geoprocessing toolbox for street data processing. If it has an own format, you might need to write your own converter (you might take a look at the VBA sample for 9.3).
Good luck!
