Network Analyst Flip Line direction by Order Sequence
4268
13
04-16-2018 08:06 AM
DevinUnderwood3
I want to flip all route lines according to the orders sequence numbers.
I would then show arrows with the correct direction of travel.
I tried using the Sort tool to resort records according to the sequence number.  I must be mistaken that it does not resort/flip the lines and direction.
Is there a possible way to accomplish what I am attempting to do ?
Thank You.
Tags (4)
DanPatterson_Retired
What did you sort on? Sorting on the geometry won't flip lines.
Flip does is you have an advanced or standard licence http://pro.arcgis.com/en/pro-app/tool-reference/editing/flip-line.htm
DevinUnderwood3
I am using ArcMap and have advanced license, manual flipping one by one works fine.
I sorted on sequence numbers I obtained from routing orders.
sorting on sequence numbers will just sort on those numbers, but as you well know, it does nothing to the geometry
DevinUnderwood3
Thanks for the feedback, I will have to take another approach.
XanderBakker
Esri Esteemed Contributor
Flip is the way to go as Dan already mentioned. Just some side notes:
  • The tool will modify the input featureclass (so perhaps use a copy to test it on)
  • It works with selections. If you can select all the elements that need to be flipped, the tool will only change those.
DevinUnderwood3
I agree and have performed these steps for flipping a line, it is not a practical solution for every line.
An alternative then is to use the reversed arrow symbology... it will draw in the opposite direction to that in which it was digitized.
XanderBakker
I was referring to creating a selection of all the features that require flipping and apply the tool once to flip all those features. In case you can't use the attributes to define that selection, probably a bit of code could do the trick. I have done similar things in the past. Can you share a small part of your data and indicate which attribute you use to define the order of the segments?
JaySandhu
The output route from a route or VRP is a single feature class (per route) and it is already oriented in the direction of the orders sequence numbers. I do not understand your use case to "flip" these.
Jay Sandhu
