Network Analyst: Error: The geometry is not Z-aware
9984
13
04-26-2010 11:57 PM
PhilippNeuhaus
while creating drivetime polygons, the Network Analyst gave me the error above.
What does this mean?
Thanks.
JimReynolds
OK....I'm back on this project.
Still having problems with larger service areas and I'm desperate. I am able to solve for relatively small service areas (180-240 minutes) in just a few minutes.
Solving for service areas up to 540 minutes. I've turned on Forced Chunking and set the edge chuck size down to 100,000. 200,000 did not work.  It runs for 1-1 1/2 hours using only 5-12% CPU and then crashes. I also set the polygon trimming to 5000 meters (actually I've tried from 500 to 5000 and everything in between).
Suggestions?
Any chance there is a 64bit ArcMap coming any time soon that can use more RAM?
Jim
JaySandhu
540 Minute service areas are very large and will most likely not work in dense parts of the country. As far as trim goes, I think a 500  meter trim is reasonable for large service areas.
In ArcGIS 10.1 we have added support for Hierarchy in the Service Areas which means it will solve very large service areas very quickly by travelling on the upper level roads. You can get on the Beta program and try out this functionality. The beta for ArcGIS 10.1 is coming out very soon.
Jay Sandhu
JimReynolds
Jay Sandhu
That sounds promising.....silly question, how do I get on the Beta program?
JaySandhu
You can contact your Esri rep/local office and request it, or see the details here to sign up:
http://blogs.esri.com/dev/blogs/arcgis/archive/2011/06/07/arcgis-10.1-beta-1.aspx
Regards,
Jay Sandhu
