Minimum Spanning Tree based on a street network
9304
13
07-19-2012 12:08 AM
DanielOefele
HI GIS Experts,
I hope you can help me with my network analyse problem (ArcGIS 10.0 SP2 - ArcView License)
Background:
I try to create a network of fiber optic cables to specific points along a street network.
Here is what I want to do:
I want to create a Minimum Spanning Tree based on a street network to give me the shortest path between a couple of
fiber optic access points. The MST should start at a fiber optic distribution point and "span out" to the access
points.
What I tried so far:
I tried to manage it with the Network Analyst and the 'Closest Facility' analysis. The problem is that it handles
each connection between a distribution point and a access point as a independent solution (end up in a single
route) - so its not the MST.
I am not sure if something like that is possible with a geometric network (with sinks and sources) and a flow
direction.
Thank you all for your support in advance,
Daniel
LanoYado
Yes Dan, I am sorry for that. Please kindly let me know whenever you will be done with fixing it, appreciate it.
LanoYado
Hello Dan, I fixed it and now it is working fine. Thank you.
Andres_JulianMoreno_Cardozo
Hi, I'm interested in de Spanning Tree Tools, but I can´t find the files, may you please send those files to me or a link? My e-mail is [email protected]. Thanks
DanPatterson_Retired
Andres Julian Moreno Cardozo it requires ArcGIS Pro
Point tools
