Location-Allocation
1384
04-05-2022 03:26 AM
FGGJernej
Hello,
I am looking into the Location-Allocation algorythm in ArcGIS Pro.
Say that I want to build a new emergency station and I am wondering, where would be
a perfect location. This way, I don't have any candidate locations to offer to the algorythm, I am
just wondering where the best candidate would be.
Can this problem be solved?
JaySandhu
The Location-Allocation solver always needs to have a set of candidate locations to choose from. In real life there are many constraints that will restrict placing a location at the most ideal position. For example there may be a swamp or an already existing structure.
So in case you do not have viable locations where you can locate a facility then you can make a synthetic data set. You can create a grid of points spaced 1 mile apart (or what ever distance makes sense for your problem area) and use them as the candidates or you can use the Create Random Points tool and create points spread out in your study area.
Jay Sandhu
