how to make feature class layer and attributes for network analyst in gis
3965
12-11-2015 11:53 AM
ESAMKHAWANDANAH
how to make feature class layer and attributes for network analyst in arc gis
ChrisDonohue__GISP
Here's a starting point:
Network analysis workflow
ArcGIS Desktop
Caveat - this is how the process works in ArcMap 10.0.  They can be some variation if you are using a different version of ArcGIS, and I have no idea if it works the same way if you are using other software, like ArcGIS Pro.
Chris Donohue, GISP
ESAMKHAWANDANAH
DEAR SIR
THANS ALOT FOR YOUR ATTENTION TO MY QUESTION, I AM USING ARCGIS 10.3.1
FreddieGibson
Honored Contributor
Are you asking how to create data to build a network dataset against or are you asking how to create feature classes that will allow you to more easily import your analysis data (i.e. stops, destinations, routes, etc.) into an analysis layer?
