How to get IFeatureclass from ILayer
1309
03-06-2013 02:31 AM
pavan_kumarmuttigi
Can any one help me in getting the IFeatureClass from ILayer instance?
Thanks in Advance
PatrickStevens
Hello!  I am going to make some assumptions.  Please correct me if I'm wrong.
Since you are posting on the Network Analyst forum, I will assume that you want to get one of the NAClasses out of an NALayer.  For example, you want to open a Closest Facility layer and access the Facilities as a feature class.
You already have a layer as an ILayer.  Cast your ILayer as an INALayer.
   var naLayer = layer as INALayer;
Via the context and NAClasses, get the naclass and cast it as a feature class.
  var facilitiesFeatureClass = naLayer.Context.NAClasses.get_ItemByName("Facilities") as
IFeatureClass;Here is a code snippet that also works:
public ESRI.ArcGIS.NetworkAnalyst.INAClass GetNAClass(ESRI.ArcGIS.NetworkAnalyst.INALayer3 nalayer, System.String naClassName)
ESRI.ArcGIS.NetworkAnalyst.INAContext naContext = nalayer.Context;  ESRI.ArcGIS.NetworkAnalyst.INamedSet namedSet = naContext.NAClasses;  ESRI.ArcGIS.NetworkAnalyst.INAClass naClass = namedSet.get_ItemByName(naClassName) as ESRI.ArcGIS.NetworkAnalyst.INAClass; // Dynamic Cast  return naClass;
pavan_kumarmuttigi
Hi Patrick Stevens,
Thanks for your help.
Thank You once again.
markspend
Hey Patrick thanks for providing us the good material about getting IFeature class from ILayer.
